##題目 Write a program to find the node at which the intersection of two singly linked lists begins.
For example, the following two linked lists:
A: a1 → a2 ↘ c1 → c2 → c3 ↗ B: b1 → b2 → b3
begin to intersect at node c1.
######Notes:
- If the two linked lists have no intersection at all, return null.
- The linked lists must retain their original structure after the function returns.
- You may assume there are no cycles anywhere in the entire linked structure.
- Your code should preferably run in O(n) time and use only O(1) memory.
##翻譯 寫一支程式找出兩個連結陣列的第一個交集的節點。
######注意:
- 如果兩個連結陣列沒有交集,回傳null
- 連結陣列必須保持他們的原始結構
- 可以假設不會出現迴圈連結陣列
- 程式只能在O(n)的時間跑完而且只能使用O(1)的空間
##思路 先判斷A跟B哪個連結陣列長度比較長,接著移除較長那邊前面的節點,接下來就兩兩節點比較是否相等。
##解題
* Definition for singly-linked list.
* function ListNode(val) {
* this.val = val;
* this.next = null;
* @param {ListNode} headA
* @param {ListNode} headB
* @return {ListNode}
var getIntersectionNode = function(headA, headB) {
// 判斷headA, headB 哪個比較長
var diff = getDiff(headA, headB);
// headA比較長,跳過前面多出的部分
if(diff > 0){
while(diff > 0){
headA = headA.next;
diff--;
} else {
// headB比較長,跳過前面多出的部分
while(diff < 0){
headB = headB.next;
diff++;
// 毎個節點進行比較
while(headA !=null){
if(headA == headB){
return headA;
headA = headA.next;
headB = headB.next;
return null;
// 取得兩個linked list長度差異
function getDiff(nodeA,nodeB){
var aLength = 0;
var bLength = 0;
while(nodeA != null ){
aLength++;
nodeA = nodeA.next;
while(nodeB != null ){
bLength++;
nodeB = nodeB.next;
return aLength - bLength;
