SPI clock stops clocking low pulses when peripheral is powered on (time-to-digital AS6500 chip) #1072
Posted at 2021-08-27 by @gfwilliams Have you connected the |
Posted at 2021-08-27 by user133661 Yes, I have connected all GND wires together. I have tried powering both devices from USB (USB -> Espruino Wifi -> external board connected to GND and 3.3V pins of the Espruino Wifi) and also tried powering both boards from an external 3V power supply (not 3.3V, only 3V...) using the GND and 3.3V. pins of the Espruino Wifi with USB disconnected. The output in the logic analyser looks the same - when the external board powers up, SCK stops pulling low. |
Posted at 2021-08-27 by user133661 I found the error, one of the pins of the dev kit board is actually mislabeled in the data sheet. I have reported this to the manufacturer now. |
I am trying to get SPI communication to work between my Espruino Wifi and a time-to-digital dev kit.
If the dev kit board is powered off, the SPI signals from Espruino looks good (I am using a logic interface to debug). But as soon as the dev kit board is powered on, the SCK clock signal stops pulling low, -it is always high with some sporadic short low pulses.
I am a programmer with very little experience from the world of electronics. Does anyone have an idea what could be wrong?
Kind regards,
Johan
