Execute code/function on puck.js from another ESP board #1074
Posted at 2022-01-24 by @gfwilliams
You could connect, but it's a lot of work. However you could make the ESP32 advertise the time via Bluetooth Low Energy (what are you programming the ESP32 with?). You could then use |
Posted at 2022-01-24 by @fanoush which is exactly what is currently discussed in topic http://forum.espruino.com/conversations/372114/ It is just few lines on ESP32 to enable NTP over wifi and advertise time over BLE (if you are ok with accuracy to 1 second) |
Posted at 2022-01-21 by user130485
Hi everyone
I am trying to set the time on Puck.js from another device (ESP32).
I am not able to run from the battery as my electricity meter sometimes gets stuck on pulse LED high and after some time hangs Puck.js and drains the battery. So I am running it off mains power (3.3v), but due to that and it sometimes rebooting, I cannot keep the time in sync with real.
My other ESP32 device is withing BT reach to Puck.js and I just wondered if I can make it connect to Puck.js and somehow set the time on it
Any help with time sync would be much appreciated =)
