[SOLVED] ADS1x15 module is not really compatible with ADS1115 #1082
Posted at 2022-08-09 by @gfwilliams Thanks for figuring that out! Is everything else basically the same though? So as far as I can see the ADS1015 would run at 1600 samples/second by default while the ADS1115 is only 128 (which was the default in both cases) - but everything should still work ok? It's frustrating not having an I2C WHOAMI register! I thought pretty much every device had them now. I'd have said duplicating everything just for that might be overkill - what about extending the So then anyone using this already would have it work fine, but it could easily support the ADS1115 |
Posted at 2022-08-23 by @yerpj Thank you @gordon. I tried to implement this feature according to your recommendation and made a pull request here: espruino/EspruinoDocs#665 However, when testing, I got this error It is most probably a very noob, basic javascript error. Could you help me figure out what's going wrong with the way I made the change? |
Posted at 2022-08-24 by @gfwilliams I think it's that you're using 'default arguments' which is a newish JS feature that Espruino doesn't support yet. I've just merged your PR and hopefully tweaked it though |
Posted at 2022-08-24 by @yerpj Thank you very much, I must say that I didn't look so deep into other modules to check how optional parameters were handled. |
Posted at 2022-08-05 by @yerpj
I just made a few experiments with an Adafruit 1115 breakout board along with the module EspruinoDocs/devices/ADS1X15.js. I compared the datasheet of ADS1115 and ADS1015 and it appears that the datarate config (DR[2:0]) is not the same. Thus, the ADS1X15.js is only valid for ADS1015. As long as the ADC type cannot be discovered at runtime, it may be better to make 2 modules instead of one, but it means renaming the js file. I don't know @gordon what would be the best way to go because renaming the current js module will break compatibility for those who currently use it.
Any hint?
Kind regards,
