Writing Tutorials #1158
Posted at 2014-08-10 by lavamantis Hi Gordon, I'm on OSX so I can't really use the instructions at the end of the "Building" section of the README.md. I'm a nodejs developer by profession so I have just about everything else required (I presume) except for what looks like a custom script to build the HTML from github. I'm making a sort of "Espruino for Dummies" page with helpful info about what people should learn as background and what tools to have on hand when beginning with Espruino development. I want to make sure the links work as expected before I do a pull request. How can I obtain the custom build script and execute it on OSX? I'd be happy to update the README with the instructions as well. Thanks. JB |
Posted at 2014-08-11 by @gfwilliams Thanks for writing the guide - that'd be great. If you've got node, all you should have to do to run the tool is:
(assuming you have the right modules) and all the html files will get dumped into the |
Posted at 2014-01-23 by @gfwilliams
Hi! If you want to write/modify a tutorial for the website, I've added some quick information here that might help:
http://www.espruino.com/Writing+Tutorials
If you write a post on the forum then it is in markdown (the same as the Espriuno documentation) - which means you can basically copy (from the 'post edit' page) and paste it into a tutorial which can appear on the Espruino website.
