Cannot build espruino: Linux #1239
Posted at 2021-08-27 by @fanoush try pip from python3, maybe try |
Posted at 2021-08-27 by yngv126399 tried that... same exact error. This is on a linux instance i rent (liveinhost.com). BTW on Windows, I used manual method and got espruino built as a local executable on my WSL, but cross compile example failed! I went to my linux instance thinking it was a cleaner solution... |
Posted at 2021-08-31 by @gfwilliams That's an odd one. Not sure why you're having issues - definitely looks like You could try running through the steps in provision.sh manually and seeing where the issue is? If a |
Posted at 2021-08-31 by @fanoush It is actually 'nrfutil' not 'nrfutils' as I wrongly suggested. also you can try |
Posted at 2021-09-06 by yngv126399 Got it working on another linux instance, but hope to fix this eventually. Thanks all! |
I'm sure it's me, but I get the following error :
and the contents of pip.log:
My system:
Any help appreciated!
