background images #1403
Replies: 15 comments
Posted at 2020-05-04 by @gfwilliams There are some simple examples like the minion clock And in fact you can do a full res image - you just write it to Bangle.js's storage, and then blit it direct from flash with But there's no easy way to do flicker-free rendering since there's not enough RAM for a full-screen buffer. In your tux example there are areas of solid color, so nothing stops you from just drawing the image on its own and then rendering the clock areas separately. There are some options though:
I've been considering adding a |
Posted at 2020-05-04 by FransM I tried to to this
but I am missing the format of the .img file. Kind regards, Frans. PS: I could also not cut&paste my error message from the IDE left panel. Would be a nice enhancement too. |
Posted at 2020-05-04 by @fanoush
It should work and is copied to clipboard automatically when you select block and release mouse button (unless it is very large). However it would be also nice if all output from left side could be automatically saved to some log file. Would help a lot with larger blocks that are too large for clipboard. Like e.g. dumping 4MB SPI flash memory via loop of btoa() calls :-) |
Posted at 2020-05-05 by @gfwilliams Yes, you just use the image converter, but you'll end up with a reasonably sized file for a 240x240x16 image. The easiest way is actually to do it using the IDE. Click on the 3 disc 'storage' icon in the middle of the screen, click 'Upload', choose an image, then it'll be detected and will offer you some options to convert it.
PRs are welcome ;) |
Posted at 2020-05-05 by FransM
Oh cool, didn't know it would ask for conversion when uploading so I was basically searching for the right image format and how to get to it.
Done: |
Posted at 2020-05-05 by @gfwilliams By PR I meant actually a fix for it, rather than just posting a bug report on GitHub :) There's already an issue for it, it just needs someone to actually write some code to fix it. |
Posted at 2020-05-05 by FransM Ah ok, for me PR stands for Problem Report, hence I just submitted a ticket. |
Posted at 2020-05-06 by @gfwilliams Ahh. Yeah, I tend to mean 'Pull Request' - so where someone submits a suggested change to the problem on GitHub :) |
Posted at 2020-05-07 by tom.gidden As we can For example, if I have a complicated clock-face redraw every minute (hour and minute hand update), I can ...? |
Posted at 2020-05-07 by Raik Not sure about the wear on the flash, but I would argue that you still would see a flickering clock face every seconds. As far as I understand: offscreen buffers are not drawn faster. In your case you would have to redraw the complete watch face every second because the (analog) watch hand moves. So between seconds you would need to redraw the area the hand has crossed to restore the watch face. Take a look at @gfwilliams s image clock But I guess you could do something similar for your clock too. |
Posted at 2020-05-07 by tom.gidden At the moment, my beebclock draws the face and the hour and minute hands from scratch to an in-memory image every minute. Then it draws that image to the screen every second and then draws a line for the second hand. The only part that flickers is the second hand, which I think is acceptable. Otherwise, I think the power drain would just be too high, redrawing it all offscreen every second. The problem is that the 240x240 buffer is a memory hog even at 1bpp. Fortunately for my watch face I only wanted 1bpp, so I can just about manage to do it in available memory.
Posted at 2020-05-07 by tom.gidden Incidentally, @gfwilliams... any chance of a double-buffered 240 x 240 x 1bpp display mode? That, combined with the suggested (It'd preclude widgets, I guess... unless support was added for monochrome widgets somehow) |
Posted at 2020-05-07 by @gfwilliams I've actually added some big speed improvements in recent Bangle.js builds, so you can create a 1bpp offscreen buffer and then For instance check out the T-Rex game now. |
Posted at 2020-05-07 by @gfwilliams I'd say avoid writing an image that changes to flash - that could be really bad for the flash, and is going to be pretty slow. In terms of power usage, the screen uses about 10x more power than the CPU does when it's flat out, so I wouldn't worry about doing too much computation! Also, you won't see any flicker if you overwrite the whole screen, as long as you do it with the same stuff :) |
Right........ :) |
I was wondering if it is possible (on bangje.js) to have a background image.
E.g. can I create a clock that has a background watchface?
The closest I could get it do use double buffering.
Anyone a pointer/suggestion?
E.g I want to create something like this watchface I have for my Mi Band:
https://amazfitwatchfaces.com/mi-band-4/view/2029
Or a watch like background with the clock hands blitted on top of them.
