VS Code intellisense for Espruino libs #1404
Replies: 6 comments
Posted at 2020-04-19 by @MaBecker Maybe it is possible to create the input from the source code. The reference page is created via script from the source code using build_docs.py |
Posted at 2020-04-20 by @gfwilliams Does this help at all? http://www.espruino.com/Typescript+and+Visual+Studio+Code+IDE It came up earlier that it might be a bit out of date (and it's for Typescript) but it might be a way to get started. The Espruino IDE uses Tern's type declaration format for its type info and docs: http://www.espruino.com/json/espruino.json I'm not sure if something exists already, but if not it might make sense to try and write something that created Intellisense type info files from those, as I keep them up to date already for the IDE |
Posted at 2020-04-20 by msdeibel The |
Posted at 2020-05-11 by Raik @msdeibel Did you get it to work? |
Posted at 2020-05-11 by msdeibel Didn't get to work on it yet. Also looks like I won't be for another few weeks :( |
Posted at 2020-05-12 by kri100s I use vs code for almost everything including web bluetooth development. I would be interested in using it for espruino. Do you have any template as a starting point? I would like to know how hard would it be to setup debugging for espruino in vs code. Let me know if you have that setup. |
Posted at 2020-04-18 by msdeibel
Hi everyone,
Since I'm doing most of my development work for the Bangle in VS Code I would like to know if anyone has managed to integrate the Espruino libs into Code's intellisense. If yes, how did you do that?
