Combination of setInterval and setTime rapid fires all intervals #1540
Replies: 8 comments
Posted at 2021-05-13 by @gfwilliams Hi - which board are you running the code on? The STM32-based boards run a high res timer which they adjust to match the RTC, to allow for high resolution timing. I guess it's possible that if you adjust time time during the initial calibration phase, it's possible it might confuse it. When the timers fire rapidly, does it go back to normal after some time? And what about if you call |
Posted at 2021-05-13 by Levon Hello, I'm running the original Espruino board, latest revision. |
Posted at 2021-05-14 by @gfwilliams Ok, great - I just filed an issue at espruino/Espruino#2005 so hopefully we can get that fixed at some point. There's no specific documentation on the calibration phase as far as I remember, but basically: The real time clock only runs at 32kHz, which means if you're trying to measure pulse widths, you'll bump into problems with accuracy pretty quickly... So we use the 'System Tick' timer which runs at the same speed as the processor - but we want the two to keep in sync (neither is 100% accurate). There's some code which keeps track of how many System Ticks there are for each tick of the RTC, so that when you ask for the time it can look at the system time and work back to a high res value, but in RTC time. It just takes a few seconds to figure out exactly what that should be... |
Posted at 2021-05-14 by @allObjects @levon, I suggest the following:
Optional (in addition to above): TL;DR: Assuming you use the upload function in the the IDE to get (all) the code (in post #1) onto the board, this happens: You are connected and upload the the code (into the RAM). Because you have I assume further, that you tried to fix this issue by adding all these You may read this post and then the whole conversation further this TL;DR: simple explanation how to save code that Espruino run on start? Even though some aspects have changed since this conversation took place, it points out the major difference between Espruino IoT platform and others, such as Arduino,... |
Posted at 2021-05-14 by Levon Thanks you @gfwilliams, @allObjects |
Posted at 2021-05-15 by Levon After some additional testing, it seems that making any |
Posted at 2021-05-15 by @allObjects @gfwilliams, that has obviously nothing to do with save or not top save. Also others have in the past complained about time inaccuracy. Many timers are usually started soon after power on. Since any interval / timeout messes with the calibration phase, it would be interesting to know how long that calibration phase lasts. For practically all applications it is good enough to start the related timers (time marks) after that calibration phase. A change in the firmware is required, because any other software controlled delay messes with that calibration. Sacrificing a pin, adding an RC and not repeatedly watching that pin could be used to created such a delay with current firmware. The raising could though be so slow that the time until the watch fires has great variance, and a short brown out has also an impact. |
Posted at 2021-05-18 by @gfwilliams @levon please could you post up a complete example that shows the problem of The calibration should take around 2 seconds I believe. Originally we used to delay execution of JS until everything had settled down but there were complaints about that, so now we just get started immediately. I'm pretty sure that actually setting a timeout/interval during the calibration phase won't mess everything up, as those never touch the system time (just read it). However during those initial few seconds, they may fire faster/slower than usual. Clock drift is tricky - @levon which version of Original board do you have? I think the original boards didn't have a low speed oscillator crystal (part X3). Also if you're using pin C15 I believe that can stop the external oscillator from working. Because Espruino tries to use the RTC as a base, if there is no external oscillator installed/working then it'll use the internal RC oscillator, which really isn't that accurate and would cause the time drift |
I'm trying to get Espruino to store a timestamp in Storage, and the read from it on boot and set the current time accordingly. This is the salient code:
However, when the code executes the first time after Espruino is plugged into power (not PC), all of the intervals fire incredibly rapidly (similarly to issue described here). Removing all instances of
setTimeremedies this. Not sure what kind of conflict is occurring there, any help would be appreciated!Beta Was this translation helpful? Give feedback.
