Shell branches with pull request be rebased while the request is pending? #1587
Replies: 6 comments
Posted at 2022-01-06 by @gfwilliams I don't really see rebasing or not as a problem. I know if new apps have been added at the end of From my point of view, I just want to be able to clearly see the changes that have been made and to be able to merge, and I'm not too concerned with how we get there. Because apps are pretty much independent it doesn't really matter if other apps are older in your PR - the main thing is that you're applying changes on top of the latest version of that app. Hope that helps? I've seen a few cases where PRs have included every change to the repo that happened since the user pulled (like they copied the files from the latest version of the repo over and then committed it) - I believe that's probably just user error (not a proper rebase) but it's important that doesn't happen :) |
Posted at 2022-01-06 by Raik As I consider myself a git dummy, what would be the best (or easiest way for you to handle) to commit new changes and issue PR for apps? I usually do the following:
Is this "the clean" way? |
Posted at 2022-01-06 by @fanoush You did not mention creating branch for the feature/PR. Branches are cheap :-) so it becomes
but maybe this is automatic and you just did not bother to mention it? |
Posted at 2022-01-06 by Raik Well thats why I ask ;-) Pretty sure I am not actively creating a branch. I fetch and merge from upstream online (on the GH page), then in my GitHub Desktop do a fetch on my checked out fork. Then do the changes, commit and push to my fork and then on the GH page issue the PR. Maybe GH magic is automatically creating a new branch? Dunno. Dummy. ;-) |
Posted at 2022-01-06 by dirkhillbrecht Hi, ok, thank you @gfwilliams, then I will follow a "mixed strategy": Always rebase upon master before issuing any pull requests, and then rebase "from time to time" to stay near to master, but more on a weekly than on a daily base. To everyone else: Sorry that I did not explain in greater detail what I am actually doing. I work with git for some 14 years now and in my company, we have a quite nice scheme with release branch, integration branch and feature branches. Currently, I work with the Bangle app loader repo as follows:
This way, "master" on my cloned github repo and in my workspace repo can always follow "master" of the official app loader. To stay on top of development, I do the following:
If I do that last step while the branch is already in the pull request review process, other people see my disruptive operation also and potentially must cope with it. I hoped that this was not too big of an issue and learned that it indeed not is. Regards, |
Posted at 2022-01-07 by @gfwilliams Hi, what you're doing sounds fine. However I'd say once you've got that branch for a feature/app it's easiest only to rebase it if you can see something has changed that really affects that app. If other stuff has changed I don't think it really matters |
Posted at 2022-01-05 by dirkhillbrecht
in my company, we have a strict rebase policy: Rebase your feature branch on top of the integration branch until it is ready for inclusion. I see that the branches here are usually not rebased before inclusion. A pull-request-based workflow does not make that really deasibe after all. But how are such rebases seen here if done by the pull request issuer during the pull request handling time? Encouraged? Frowned upon? Not seen as an issue?
I just don't want to annoy anyone with my branch handling...
Regards,
Dirk
