'Module not found' when trying to load any module #195
espruino-discuss
JavaScript
Posted at 2014-02-03 by @gfwilliams Ahh, right - I think this is because you're typing code in the left-hand side and the Web IDE doesn't automatically look at what you type there and load the libraries - each character goes right to Espruino, so by the time you've hit enter on a command, it's too late to load the library. Your best bet is to simply type I'll update the DS18B20 docs to mention this... |
Posted at 2014-02-02 by TheoryOfRain
I just received my new Espruino Starter Kit a couple of days ago.
When I tried to go through the tutorial on using the DS18B20 temperature sensor (http://www.espruino.com/DS18B20), I came across a weird problem: Apparently I can't load any modules. Here's what happens:
The same error also occurs when I try to load some other module from http://www.espruino.com/modules. The Modules/Config entry in the options is set to {"url":"http://www.espruino.com/modules","fileExtensions":[".min.js",".js"]} (which, I think, is the default value), and I am using Firmware version 1v48 and the Espruino Web IDE under MacOS.
Any suggestions on what I might try to fix this?
Alexander
