setInterval problem #237
Posted at 2014-03-23 by DrAzzy When it breaks, is getTime() giving bogus results? (Note, it should be in seconds) |
Posted at 2014-03-23 by arthurj getTime() does not return the correct result. It is incrementing far too fast, about 2500 per second. By the way, do you understand why it returns a value to 14 decimal places? |
Posted at 2014-03-24 by DrAzzy Sounds like the same issue I'm having in the DISK_ERR thread. |
Posted at 2014-03-24 by @gfwilliams Yes, sorry about this - it's probably the same issue and I'll be working on a fix today. The 14 decimal places is more or less random - it's probably just the maximum Espruino outputs at... It'll be because time is stored to |
Posted at 2014-03-26 by arthurj I have been running 1v59 commit_date/2014-03-25 13:14:38 for over 15 hours now and it is still working OK! |
I am having a lot of problems with setInterval. Even using the simple tutorial example of flashing a LED. If left unattended it works for perhaps two hours and then breaks with the LED constantly on. I have also tried it using digitalWrite to a pin and when it goes wrong the pin is being pulsed at a much higher rate than was set. Further calls to changeInterval have no effect, a reset is required. I have tried this on the two Espruino boards I have with the same results. I am observing this using firmware 1v58. Is this linked to the problems currently being seen for setTimeout and getTime? Any ideas?
Arthur
