Battery life of Bangle J.s - in real world situations #2500
Replies: 6 comments
Posted at 2021-03-18 by Robin Thr 2021.03.18
YES @user126405 the Bangle and all the Espruino original boards are fun to tinker with!
Simple explanation for battery ampacity
I found the specific answer for Bangle by taking a peek at the Bangle presentation page: > http://www.espruino.com/Bangle.js Below the Power Consumption heading:
From there I searched to the bottom of the page at the tutorial icons and selected 'Technical Information' Below the Features heading:
How to calculate from those values? Total capacity 350mA or 0.350A At idle, 0.15mA or 0.000 150A are consumed when there is no movement. When GPS is Note that individual mileage may vary Through your specific coding technique, GPS could be turned on and off to extend that value
Also take a look at this ongoing discussion within thread: Post #21 Bar Graph |
Posted at 2021-03-19 by @gfwilliams Hi! Did you ask on Reddit too? There's a good answer there: https://www.reddit.com/r/Banglejs/comments/m7v4sc/battery_life_of_bangle_js_in_real_world_situations/ I'm biased, but I find with the latest firmware around 2 weeks is sensible. If it's just sitting there doing nothing you'd be looking at well over a month, but the biggest power draws are the LCD and GPS, so how long you have the LCD on for (for instance whether it comes on automatically with hand movement) can have a big effect. GPS doesn't normally come on unless you enable something that uses it (like GPS recording), and then you could be looking at ~10 hours usage. @hughb has done some great work on this though and with the GPS Setup app you can tell the GPS you only want a GPS fix every 2 minutes, and in that case you can be looking at almost 2 days of constant usage. |
Posted at 2021-03-19 by user126405 Wow! Great info. Thanx. Looks like I will be buying one then :-) |
Posted at 2021-03-19 by user126405 Yes, sorry. I posted on Reddit before I realized that there s an official forum. I presume that thsi one gets most traffic? |
Posted at 2021-03-22 by @gfwilliams Honestly, it's hard to know what gets looked at more. I'm not sure the forum is very search-engine friendly. I do try and read the Bangle.js subreddit but I'm conscious that because I'm pretty biased it's not always a great idea for me to post replies there ;) |
Reliable electronics depend on components that quietly keep systems stable and efficient. From power supplies to consumer devices, proper current control is essential for safety and performance. At the core of this reliability are Diodes - Rectifiers ensuring smooth current flow and protecting sensitive circuits from damage. Their role may seem minor, but without them, modern electronic systems would struggle to operate consistently and safely. |
Posted at 2021-03-18 by user126405
The Bangle.Js looks like it could be fun - programmable in JavaScript and with GPS.
BUT, I am unsure about the battery life.
How long does it last in normal usage? Both with and without GPS (if that can be turned off)
