Funny newbie error - renaming Reset by accident :) :) #252
Posted at 2014-04-07 by @gfwilliams Oops! :) You can either: Or probably the most important way out (mentioned in troubleshooting) is: Press and release RST, and press BTN1 immediately after. Not too soon after though (or you'll get the bootloader mode with the glowing LED)... Once you've done that, Espruino will start up without loading the saved program. You can then just type |
Posted at 2014-04-07 by mgg1010 I think I tried delete(reset); and some JS documentation I found online suggested you couldn't delete vars. I probably just missed it. I think I found the BTN1 fix by accident. Thanks :) |
Posted at 2014-04-08 by @gfwilliams No problem... I only implemented |
Posted at 2014-04-08 by mgg1010 Well, entering 'delete' into the search UI gives "no results" which probably stopped me a bit :) |
Posted at 2014-04-08 by @gfwilliams Ahh. Yes, it's just a built-in JavaScript keyword, and the search only covers the documentation and function reference. I'll add it to the FAQ... |
Posted at 2014-04-06 by mgg1010
Hi
Without thinking about it, I created a script with
var reset=0;
in the top level. I then used save();
Once I'd done this, I obviously couldn't use reset() to clear the memory, and
hard-reset reloaded the same program..
I really couldn't see how to get out of this. But I messed about for a while and
eventually somehow it went away.
If there is a way to undefine a variable or clear the program memory without using
reset() it would be useful to document here please :)
