Cannot connect to Puck.js after updating Firmware to v1.99 with Windows 10 #3002
Replies: 6 comments
Posted at 2018-08-22 by Robin Wed 2018.08.22 Have you attempted to flash using a previous version? If so, did full functionality return? Try this first though: Was the Puck connected to another BT device? I believe that step of unpairing has to occur, before re-establishing BT after update. Searching for documentation. . . . **EDIT** Ahhh . . . Here it is: Inside: http://www.espruino.com/Puck.js#troubleshooting see: 'Troubleshooting' find: http://www.espruino.com/Troubleshooting+BLE beneath the heading: 'I can't see my device any more'
Posted at 2018-08-23 by MobiTech Got it by doing a reset after downgrading the firmware and then upgrading it again. |
Posted at 2018-08-23 by @gfwilliams Glad it's sorted - did you do a reset after upgrading by long-pressing the button when powering it on? That can sometimes help. |
Posted at 2018-08-23 by MobiTech Yes, I did. But I did that already before downgrading and it did not work. The only solution was to downgrading to V1.95, doing a reset, upgrading to V1.99 and doing a reset again. Might be a problem that I upgraded from V1.88. |
Posted at 2019-06-24 by user101316 Thanks Mobitech. works great. |
Posted at 2019-06-24 by @allObjects
...surprise to me... I see nothing mentioned in http://www.espruino.com/Puck.js#firmware-updates So it must be that before attempting to update directly to 2.03 from 1.88, some application residuals have been left over... Did you do a |
Posted at 2018-08-22 by MobiTech
I have a problem to connect to Puck.js after updating the firmware to 1.99. I tried to connect to the bluetooth device via bluetooth device manager on windows. But I always get an error that I should try it again. When I try to connect to beacon using the NRF connect App it works well.
Do you have any idea? Before the update it worked without any problem.
