Puck Advertising Private Characteristic and r/w #3019
Posted at 2019-07-19 by user101905 Update: Im done with second characteristic and it works. But with notify it stocks. Here is the Code: And the update code: The state switch and I can set Notify into the BLE App but no notification received. |
Posted at 2019-07-19 by Robin Fri 2019.07.19 Hi @user101905, there are many links to assist that I just posted in a separate user thread:
This is a good starting point: |
Posted at 2019-07-22 by @gfwilliams Ok, so it looks like your first issue (getting the data in a write notification) is sorted?
You just add an extra element to the object. For example: What you're doing with updateServices looks fine. All I'd say is it's far more efficient to use the same basic UUID and to change the second group of 4 digits as you did in the first example. I just tried this code and it works fine: |
im totally new with Puck.js and Javascript at all but I'm trying to advertise a own private Characteristic with 2 Services.
One service to controll the LEDs from the Puck from a external device and the other service for button state from Puck.
First Service is writable from external device, the second one is just readable but with notifications.
That code works, if I'm writing into the service the LED1 rises. But i want to check what value is transmitted. But I cant find any documentation about NRF.setServices so I dont know how to read out the value.
How do I make the second service with button state?
A bit off topic question: As I saw the Puck only can connect with one device at once, thats ok but later I want that the code is execute during boot, is it still possible to access from Espruino IDE then?
EDIT: Okay, I found that code:
digitalWrite([LED3,LED2,LED1], evt.data[0]); which reads the value and works fine. But how to do the second task?
Also: I need to restart iPhone (use BLE Scanner) after changing the Services. Otherwise it will not displayed. Very irritating. Is there a workaround?
