Uncaught InternalError: Timeout (Magnetometer) #3046
Replies: 8 comments
Posted at 2017-05-10 by @gfwilliams Are you using up to date (1v92) firmware? Also, the only time I've come across this before has been when the battery is almost flat - the main processor works fine but the magnetometer stops working slightly before the ARM has trouble. Please could you check |
Posted at 2017-05-10 by badryan Says 1v88. Battery level is shown as 100, but I know that can't be true. Is there a video for firmware updates using iOS? Watched the Android one, but the iOS app looks quite different. |
Posted at 2017-05-10 by badryan Upgraded to 1v92. That fixed it. |
Posted at 2017-05-10 by @gfwilliams Great! I'm afraid there isn't a video for iOS - I'll make a note to create one. |
Posted at 2019-08-07 by user101989 I reproduced this behavior with a flat battery showing 0 or 10 with E.getBattery(), not sure why the oscillation, but the magnetometer failed to record even though other components were still functional. Changing to a new battery brought the magnetometer back to life. firmware 1.99 |
Posted at 2019-08-07 by Robin Wed 2019.08.07
Basic physics, based on lack of sufficient voltage supplied. See p.17 nominal voltage is 3v - device unpredictable below that level, especially the AD as it's readings are ratio-metric based on voltage reference See 'Continuous Discharge Characteristics' graph in datasheet:
The calculation
Other discussions but for different board: |
Posted at 2019-08-07 by user101989 Thanks for the info! Ill read up, i suck at basic physics |
Posted at 2019-08-08 by @gfwilliams Thanks for letting us know! I'll add a note to the docs. By the time the magnetometer fails the battery is almost completely dead - it just happens that the microcontroller is a little better at eeking out the final few percent than the magnetometer is! |
I'm using the magOn event to report magnetometer readings. As shown in the example for the Door Controlled Light, I defined a global variable zero and calibrate the sensor with the readings of an initial Puck.mag() call. However, when I try and use Puck.mag() out of the convenience of a setWatch function upon a button press, I get the above error message.
Can anyone tell me what's wrong here?
and I receive something like
