serial interface on MDBT42Q #3073
Posted at 2019-08-26 by AkosLukacs You can force the console to Bluetooth with |
Posted at 2019-08-26 by user102708 awesome! thank you |
Posted at 2019-08-26 by @fanoush The automatic switching can bite you also in other cases. It surprised me first but after thinking about it, is now clear because console is done via just another BLE service so it is not known which service/characteristics will client use after connection so Espruino console is switched on connection event. It theory this could be changed to do the switch only after first read/write to Nordic Serial service. |
Posted at 2019-08-27 by @gfwilliams Thanks for the update! Actually it seems that it would be a bug of Bluetooth UART write fills buffers if nothing is reading from it. I'll look into that. About the original switch, I believe that if |
Not a major issue but I was wondering if there was a way to turn off the text that indicates you are switching between Bluetooth and serial on the MDBT42Q.
so when I connect over Bluetooth the serial outputs:
and when I disconnect I get
I have written a Bluetooth to serial (rs232) program so I can send serial commands to devices that I have no cable path too, and the auto text complicates it a little bit. Thanks in advance.
