EspruinoHub installation fails on Raspberry Pi 3 #3130
Posted at 2019-10-15 by @gfwilliams Hi - sorry for the delay. This got buried amongst a bunch of other stuff. I'm not sure what to suggest here. I just tried with a totally standard install of Is it possible you had used If you don't have anything else on it, I'd imagine a fresh install and following the instructions for the just EspruinoHub and the IDE would work fine. |
Posted at 2019-10-15 by Gefrierbrand As far as I remember I tried both with and without sudo. It's quite possible that something got mixed up in the whole NodeJs ecosystem, which I'm not familiar with. I'll try again with a fresh raspian install sometime soon. |
Posted at 2019-10-15 by DamianMontero It's a node version thing. You can see the error is deprication. it's common to have to switch versions and if that's all your running then the right version fixes all problems. Switch to 6.0 |
Posted at 2019-09-28 by Gefrierbrand
Hi, I'm trying to get EspruinoHub to work on my RPi.
I'm on Raspbian Stretch and all packages are up to date. No manually installed "special" versions of any kind.
I'm following the steps from here: https://github.com/espruino/EspruinoHub; I'm only interested in the EspruinoHub and Web IDE Part, no need for NODE-RED.
The Setup fails at the "npm install" part with the following errors:
I'm not really familiar with node.js and npm, and I suspect the environment setup is not correct. I installed node & npm from the defailt raspbian repos.
Any Ideas?
