Flash Pages (Code, FS, Bootloader, Softdevice) #3131
Posted at 2019-10-21 by @gfwilliams
Yes, you can! Obviously the start address needs to change too, but it should be pretty straightforward. Annoyingly It probably uses 100 bytes of data in most cases, but it requires 2x 4kB flash pages to function :( It may be possible to just not include fstorage in the build and then make your own stub functions for read/write that use Espruino's Storage implementation though? |
Posted at 2019-10-21 by AntiCat Thank you for the explanation. I've looked at the interface |
Posted at 2019-10-19 by AntiCat
I've started to port old code that uses the (deprecated) Flash-Module to the Storage-Module.
With the Flash-Module I could disable features like NET, GRAPHICS and thereby increase the Storage available to me. (As far as I know, the Flash-Module uses the pages between the executable and the reserved area).
The Storage-Module, on the other hand, seems to use the pages defined by
pages: 10.Can I simply increase
pagesand decreaseflash_availableby the same amount to move the free space from the Flash-Module to Storage-Module?What are the 2 pages reserved for
FSfor?Beta Was this translation helpful? Give feedback.
