setSecurity not working as expected #3178
Replies: 15 comments
Posted at 2019-10-08 by @gfwilliams Hi, I've just looked into this, and I found that there was an issue inside the Bluetooth stack where sometimes the keys used for secure pairing weren't aligned on word boundaries. Unfortunately it looks like the Puck.js 2v04 build was one of those builds - passkey pairing would have failed and you should have been unable to access characteristic However while at that point Android will request a passkey if you connect using the OS's menu, if you go through NRF Connect it won't. It will only require the passkey either when you explicitly try to bond, or when you try to access the |
Posted at 2019-10-10 by jameshollyer The espruino_2v04_puckjs.zip file is not working for me. I even went and installed 2v03 to make sure it was not updating and that I was doing it properly. 2v03 worked just fine. That master branch version of 2v04 does not. The NRF Connect app says "Starting DFU" then immediately says "disconnecting..." I also wanted to say that I am using web-bluetooth to connect to the characteristic. Here is my code for that: Just wanted to make sure that I should not be able to access that without entering a passkey if it is working. |
Posted at 2019-10-10 by @gfwilliams Sorry about that, there was a problem with the build - try now and it should update ok: http://www.espruino.com/binaries/travis/master/ It's possible that you just won't get notifications on the characteristic? What happens if you try to read it? You could also try adding 'write': It's possible that what's happening is the characteristic is still allowing writes which allow you to turn on notifications - that's something that should probably be fixed in firmware (to automatically stop writes if read is set to require encryption). |
Posted at 2019-10-10 by jameshollyer Now http://www.espruino.com/binaries/travis/master/ does not even have a file for puck js. |
Posted at 2019-10-10 by AkosLukacs Looks like there was a build glitch.
Posted at 2019-10-11 by @gfwilliams It's fixed now thanks to @AkosLukacs so the files will be back in http://www.espruino.com/binaries/travis/master/ |
Posted at 2019-10-11 by jameshollyer That did the trick. Much appreciated! |
Posted at 2019-10-30 by jameshollyer I would like to open this back up. I am not sure this is working properly. It is now prompting me for the passkey on mac os and android(using the nrf connect app). In Mac when I enter the key it gives me an "unkown error" and on the NRF connect app it acctually disconnects me from the puck when I enter the passkey. My current code is : everything works fine on characteristic 0xAB40 but I cannot get the secure 0xAB41 characteristic to work. Please advice. |
Posted at 2019-11-01 by @gfwilliams
But it was working? Did you change anything? Can you try just fully restarting the Mac? I know it seems dumb but it has been an issue before that the Bluetooth stack gets confused. |
Posted at 2019-11-05 by jameshollyer I don't think it was ever working. When I said it was working it is because the passkey prompt popped up. I was never able to connect to it. I thought I was reproducing a reported Web Bluetooth bug in Chrome. However, when I dug further I found the issue was in the call to Core Bluetooth. I have now made a standalone Objective C OSX application that uses core bluetooth to connect and I am still getting the error. I then tried it on the NRF Connect app and it did not work there. I also tried through Chrome's web bluetooth on Windows and it did not work there either. This is leading me to believe the issue might be in the Puck. I did restart my Mac and try again and I am still not able to connect to the protected characteristic. |
Posted at 2019-11-21 by jameshollyer Ping |
Posted at 2019-11-21 by @gfwilliams Just spend a few hours looking into this. If you'd put setSecurity after setServices it would have worked I believe, although there are some other issues.
So if you do the following, you should be good: |
Posted at 2019-11-21 by @gfwilliams I'll get a new firmware out in the next few minutes that has the issue with ordering fixed though |
Posted at 2019-11-21 by jameshollyer Thanks for looking into this Gordon! How are you testing that this is working? I am using the NRFConnect app as a source of truth. I uploaded your code to my puck and tried to get the secure characteristic from that app and once I entered the passkey it just disconnects(same as before). I am also trying on an objective-c core bluetooth application I wrote to test connecting to the app and I get an "unknown error" after I type in the passkey(also, same as before). I am wondering what you are using to show that is does work as intended? I will try again with the new firmware. |
Posted at 2019-11-22 by jameshollyer Ok it is all working now with the newest firmware. Thanks a million Gordon I really appreciate it. ps. That watch is awesome! |
Posted at 2019-10-07 by jameshollyer
I am trying to get some sort of proof that there is any security things happening at all. Most notably is that there is no prompt for a pin at any point.
Here is all the code I am uploading to my puck.js although I don't think anything but the first line(obviously copy pasted from the docs) is relevant.
Puck js is updated to 2v04.
