UI suggestions #3253
Posted at 2017-06-13 by @gfwilliams Hi, thanks - good ideas! I've actually got some issues open for the two things you mention already - so hopefully they will get implemented at some point soon.
You can download manually at the moment by typing And if you want to change the name there's the should work - so if you upload the following code and then type (edit - just moving this to the Puck.js forum) |
Posted at 2017-06-13 by davidhay Thanks for the rapid reply! I was aware of setAdvertising, but that line is replaced each time the code is updated isn't it? Unlike the 'Puck.js xxxx' name... So you need to remember to change it to the 'correct' name each time you update the device, which gets confusing (at least for me) when dealing with multiple devices... (but the ability to dump() the current code - and eventually the current device name in the banner - will certainly help... cheers... |
Posted at 2017-06-14 by davidhay Ah - just read your reply properly. Works perfectly - thanks! |
Posted at 2017-06-14 by @gfwilliams Great! You can also just type this on the left-hand side: It'll then execute that code even after a call to |
Posted at 2020-01-23 by @gfwilliams You can now click the |
Great little device (the Puck)! Couple of UI suggestions for the editor:
(would also be good to be able to permanently change the device name - but I suspect that's not possible)
cheers...
