sending code to puck.js causes reset() error #3283
Replies: 6 comments
Posted at 2019-12-19 by @allObjects ...since |
Posted at 2019-12-20 by dysc Thanks for explaining the background on the communication channel - seeing this I now understand the reason for the error. Using your code snippet fixed the error, thanks for that, also! |
Posted at 2020-01-06 by @gfwilliams I'm not sure if this helps, but: would happen if you did something like |
Posted at 2020-02-05 by dysc Thanks for your idea & feedback, Gordon! This error occurs prior to loading code to the puck, seems to be during the (standard) reset during the upload procedure - AFAIK there was some switch to "disable reset upon code upload" in the Web IDE... |
Posted at 2020-02-05 by @gfwilliams The standard reset procedure involves just calling |
Posted at 2020-02-07 by dysc Thanks Gordon - that's it! That was the issue - I did have a variable called "reset" which caused this behaviour... Sorry, my bad... Will now close this thread |
Posted at 2019-12-19 by dysc
Hi all,
been working with the puck.js for a while now and every now and then I get an error upon loading code (via WebBT/Chrome) to my puck.
It seems to trigger a reset which seems to fail:
See also attached screenshot - this happens even when just loading one line of code to the puck...
(hard-)resetting the puck fixes that for a while, but the issue eventually comes back.
Any ideas?
