Disabling Hard Reset Puck.js #3296
Posted at 2020-02-09 by Robin Sun 2020.02.09
Has an attempt been made to extend the startup call to onInit() been extended, such that a conditional step would then allow the saved code to then execute? Should additional assistance be required, please post your startup call to the onInit() function. |
Posted at 2020-02-10 by @gfwilliams I'm afraid there isn't a way of disabling the removal of 'boot code' in Espruino at the moment, it's built into the firmware. However on a long-press, the only files that get removed are the ones created by If you write your code to I'm afraid bonding data will still be cleared though. |
Posted at 2020-02-10 by tronic98776 Thank you Gordon. That should be perfect. I'll give it a try. |
Posted at 2020-02-20 by tronic98776 I'm having trouble getting this to work. For eaxample here is what I'm trying to write to .boot0 and have it execute on device start-up, but it's not working for me: So i have nothing in save(), so do not enter the save() command into the terminal, I just send the above code onto the puck via the IDE, then disconnect from the IDE and restart the puck by cycling the power. I have tried both including the onInit and leaving it commented out as above. Do I have something wrong, or is it something to do with the ble_hid_keyboard service not working from boot0? |
Posted at 2020-02-24 by @gfwilliams Ahh - yes, it's because Maybe try using https://www.espruino.com/ide/ to write the code - I just pushed some changes I'd had locally that make this much easer.
Posted at 2020-02-09 by tronic98776
I'm looking for a way to disable the hard-reset that is initiated by holding down the button on power up to clear out any previously saved code and bonding data. Is there a command I can add into my code that will prevent this function?
I understand there are certain risks with doing this but I want to prevent the chance of erasing the code accidentally.
I would like to still have the self-test function intact where you can power up the puck without loading the saved code and without deleting the saved code.
many thanks
