ANT+ (or ANT) example? #3299
Posted at 2020-02-24 by @gfwilliams Hi, Espruino doesn't support ANT natively at all I'm afraid, however the softdevice used on Espruino does, and @conoroneill had done some work compiling a custom firmware that did some stuff with it I believe? But if both support BLE, I'd strongly suggest using that instead - it'll be so much easier for you to use and debug the communications with it, since you can use phone apps like NRF Connect to easily show you info about the devices. |
Posted at 2020-02-24 by ConorONeill Unfortunately I got distracted with building Espruino on Particle Xenon and never got back to looking at ANT+, sorry :-( |
Posted at 2020-02-25 by HaraldK Thanks! I'll heed Gordon's suggestion and use BLE instead then. Especially since Conor didn't work on ANT either. |
Posted at 2020-02-24 by HaraldK
I got 2 Puck's and a Garmin smartwatch. Both can use BLE as well as ANT. There are unfortunately no examples for ANT or ANT+.
Does Espruino support ANT or ANT+ in any way?
If not, I'll have to go the BLE route it seems.
Harald
