MDBT42QRemove library from build #3334
Replies: 8 comments
Posted at 2020-04-25 by Robin Fri 2020.04.24 While I have only done this task one time, I am only able to respond for one specific OS. Until others are able to respond, Which PC OS is used? Was a successful build performed with no modifications prior to start? |
Posted at 2020-04-25 by user106664 MacOS and the default python versions is 2.7. I had a look don't think theres another GNU Arm Embedded Toolchain installed on my machine. What operating system did you use? I might spin up an Ubuntu VM. Thanks for the help. |
Posted at 2020-04-25 by Robin Sat 2020.04.25 Windows10 I'm not going to be able to assist here as Windows uses a somewhat convoluted meas to store it's files in multiple locations. Typically as Microsoft products require a license, I don't think a Win10 build on a VM would be a picnic either. Just had a thread that might have provided insight if on Win10. |
Posted at 2020-04-25 by @MaBecker Hi get gcc-arm-none-eabi-8-2018-q4 for mac and check the build readme section Mac https://github.com/espruino/Espruino/blob/master/README_Building.md |
Posted at 2020-04-25 by user106664 Robin no problem thanks for the response. Hi MaBe, I followed the build process and the gcc-arm-none-eabi-8-2018-q4 for mac installs under the Epsruino directory in folder gcc-arm-none-eabi-8-2018-q4-major. The issues relates to the binary not executing, Espruino/gcc-arm-none-eabi-8-2018-q4-major/bin/arm-none-eabi-gcc: cannot execute binary file |
Posted at 2020-04-25 by @MaBecker Check with file |
Posted at 2020-04-25 by user106664 Good spot : file arm-none-eabi-gcc Assuming i'll have to uninstall and reinstall with correct version? Per your link. |
Yes ;-) |
Looking for guidance on how to generate the binaries/zip files with certain libraries added or removed, i.e if I wanted to remove the net library from MDBT42Q . I've seen it mentioned in this forum and that it should be relatively straight forward but couldn’t find any tutorial (n.b i’ve looked at the build example) Hopefully this thread will act as a guidance for others. Outlined stops i’ve following below with current errors / queries.
2.Navigate to the directory
5.make clean && BOARD=MDBT42Q RELEASE=1 make
Having an issue with this step, getting following error
Espruino/targetlibs/nrf5x_12/components/toolchain/gcc/gcc_startup_nrf52.o] Error 126
Finally if build was successfulm where relevant binaries or zip file for DFU be?
