options for NRF.setAdvertising? #3345
Replies: 6 comments
Posted at 2020-04-27 by @gfwilliams
What data? The number like 0x180f? Check out the link to the Bluetooth SIG in http://www.espruino.com/About+Bluetooth+LE#uuids
Each device has its own MAC address - that's how it works, like Ethernet/WiFi/etc. You can change it with |
Posted at 2020-04-27 by David1234321 let me explain myself:
but I;m steel able to connect to "test1" - why? 3 . I want to change my own MAC for testing issue , so I will know which MAC I'm testing, |
Fourth line down on https://www.bluetooth.com/specifications/gatt/services/
That's fine, it happens automatically. This post from a few days ago is just what you need: http://forum.espruino.com/conversations/346289/#comment15233728
Are you sure it's actually executing? That should definitely stop connecting. You could also see http://www.espruino.com/BLE+Security |
Thanks , |
Posted at 2020-04-28 by @gfwilliams
Probably, yes |
Posted at 2020-04-28 by David1234321 Thanks , |
Hello ,
I have read the Reference for the NRF.setAdvertising , and something is missing for me.
For example
but how do I get this data ?
also where is the lines I can edit ? which options I can use\edit?
is there a list of thing I can use?
also
when I scan my device I can see that the MAC is
why is it?
what is the different between
Public,statis,random?
what do I need to use?
Thanks,
