delete data from flash in MDBT42? #3373
Replies: 14 comments
Posted at 2020-05-18 by @gfwilliams Using Are you using firmware 2v05? |
Posted at 2020-05-18 by David1234321 doesn't get rid of the file just to be sure - wher do I see the version? |
If you just type |
when I run the code but when I run list I can see the file maybe this is my problem? and how could it be ? |
Posted at 2020-05-18 by @gfwilliams As a first step, please could you try installing up to date firmware? Looks like you're on 2v04 and there is 2v05 which has a fix for some storage related issues |
Posted at 2020-05-18 by David1234321 I need to be neat the device fot this - I see |
Posted at 2020-05-19 by David1234321
I download the zip file - espruino_2v05_mdbt42q.zip |
Posted at 2020-05-19 by @gfwilliams Are you on Mac OS? Please could you try uploading firmware using the instructions at http://www.espruino.com/MDBT42Q#firmware-updates (so using the nRF Connect app on Android/iOS instead) |
Posted at 2020-05-19 by David1234321 Using WIndows7 |
Posted at 2020-05-19 by @gfwilliams Windows 7 doesn't even support Web Bluetooth I'm afraid, so the firmware updater built into the IDE won't work. Do you have an iOS device available? Or do you have no smartphone/tablet that can be used at all? |
Posted at 2020-05-19 by David1234321 yes I do I have also have a computer with win10 - better? |
Posted at 2020-05-20 by @gfwilliams
Yes, that'd be perfect. Just use that to do firmware updates.
That would be better for doing development, as you could use the online IDE at https://www.espruino.com/ide/ However for firmware updates the Android devices are actually faster |
Posted at 2020-05-20 by David1234321 OK Thanks, |
Posted at 2020-05-21 by @gfwilliams Try |
Hello ,
as I understadn I can use about 40kb~ of memory in the MDBT42
I have code that save into RAM and then move it to the flash
I can see the RAM is clear without a problem
then I send this information to another devcie and after a while I want to clear the flahs
but I'm unable to do this
this is the command I'm using :
but it doesn't work
why?
