Puckjs failed to update firmware over Web IDE and now it won't boot #3394
Posted at 2020-06-08 by @gfwilliams Hi Adam, Please can you try updating using the nRF connect Android or iOS app?http://www.espruino.com/Puck.js#firmware-updates That'll likely be able to connect and will fix the problems. What Operating System were you running the Web IDE from? |
Posted at 2020-06-08 by user113493 Web IDE in Windows10 Chrome. I tried nRF iOS and it can see the device as DfuTarg when the green light is on but then fails to update (connection timeout in log) |
Posted at 2020-06-08 by @gfwilliams Hi, Is this a new Puck.js you just got? Does the green light look bright, or dim? It's possible the battery is flat, and that it fails halfway through the update process. |
I tried to update over Web IDE but it failed. After soft reset there is no red light now, with button pressed there is green and then green and blue. I can't connect from nRF app or Web IDE.
Any help would be much appreciated.
Adam
