How can I connect Puck2.js to PN532 NFC/RFID ? #3410
espruino-discuss
Posted at 2020-07-24 by @gfwilliams What you're doing sounds good. You could try software I2C just in case? That'll be able to use the internal pullup resistors which may work if the PN532 doesn't have any. Another issue could be the voltage. IIRC the PN532 needs quite a bit of power to get its coils working - it's possible that the 3v CR2032 doesn't supply enough power. In that case, you'd just have to:
Posted at 2020-07-24 by user67655 OK,thank you! |
I have a PuckJS 2 with 2v06 and a PN532 NFC v3 module from Elechouse, connected as follows:
Puck.js_D28 to PN532_SCL,
Puck.js_D29 to PN532_SDA,
Puck.js_3V to PN532_VCC,
Puck.js_GND to PN532_GND,
Puck.js works fine and the red LED on the PN532 is also active.
Actually I use the Espruino Web Ide Tool, so:
I see now the following on the web console:
2v06 (c) 2019 G.Williams
Can somebody help me, what could be the problem?
Thank you!
