brand new puck.js v2 – already bricked? #3460
Posted at 2020-08-24 by user117186 i feel kinda stupid. the battery simply was empty. is the "flashing red to indicate low battery" a feature? because i did not see it documented anywhere |
Posted at 2020-08-24 by @gfwilliams As you figured, at 2.8v the CR2032 batteries are basically only 10% charged.
It's not an intentional feature, but it does happen on the v2 for certain charge levels. Basically at boot the accelerometer draws a bunch of power a fraction of a second after startup, so while Puck.js boots and flashes the red LED, the accelerometer pulls the battery voltage too low and causes a reboot loop. |
i just got my new puckjs v2. Everything was working when i got it.
Here is how i apparently bricked it:
did i already brick it – anything else i can try?
edit: previously could not get any led to light up. it now blinks red – content edited to reflect that
