Digital pin failure #3644
Posted at 2021-01-28 by @gfwilliams Hi - sorry about that, I guess it was just a bad connection - but it's rare for it to happen. I'm afraid there's nothing special about D5... I could arrange to get you a replacement? |
Posted at 2021-01-28 by kri100s Ok, I was just wondering if I should use that pin for the new board version. I have to redesign anyway. It seems its just bad luck. I dont need a replacement. Its just that one pin. It works fine with D6 and I have still plenty to spare. Thanks @gfwilliams! |
Posted at 2021-01-29 by @gfwilliams Thanks! But no, there's no reason why you shouldn't use D5 - it should behave the same as any other pin |
I was playing for a while now trying to get a stepper motor working with the MDBT42Q module (breakout). It worked with default wave pattern (wave) but didnt with full step. Even the default seemed a bit weak so I finally hooked up oscilloscope to the board. It turned D5 pin was busted. I checked the bare module connection to the breakout and seemed a bit skewed but the continuity is there. I cut the track on my board and used D6 and it works fine now.
I guess I was unlucky.
Let me know if there is anything special about D5 I maybe missed. I just configured it to 'output'.
