bluetooth appears to be off #3689
Replies: 7 comments
Posted at 2021-03-17 by @gfwilliams Hi - if you can connect by USB serial, please could you run:
The most likely situation is some other device is auto-connecting to the Puck - especially if you ever configured the Puck as a BLE HID device, some operating systems decide that once connected they will just keep connecting whenever they see the device - and that stops any other devices getting connected |
Posted at 2021-03-18 by garciamax Hi Gordon, My steps were:
I also tried to run I started with 1000 then raised the time to find. No devices found. I expected it to find second Puck nearby. Maybe I can somehow debug bluetooth module itself, run diagnostics, get more info? |
Posted at 2021-03-18 by @gfwilliams
Wow, and nothing at all? Please could you try and take a picture of the area where the aerial is? (the white thing on the blue module) I guess it's possible the aerial on the Puck got damaged? |
Yep, empty array.
Could be, it happened after I was taking Puck in my jeans small pocket, but I can not detect any visual damages on the device. Attachments: |
Posted at 2021-03-18 by @gfwilliams Thanks, that's a great photo! Honestly, I think in that case it might be best to return it and swap it for a new one. It'd be the first time it's happened but it sounds like maybe something has gone wrong internally. But first, just to be sure - if you do |
thank you :)
Thank you for this, where do I send it?
Yes, it found couple of devices around (same spot as a first one). |
Posted at 2021-03-18 by @gfwilliams Thanks - I'll drop you an email now.... |
Posted at 2021-03-16 by garciamax
Hello good people,
I have two identical puck.js v2. They both fully functional untill one of them stopped appear in the bluetooth dialog when connecting to web IDE, while I see second device in the dialog just fine.
I did a reset and a hard reset, when I insert a battery a red light blinks as expected I can even connect to this puck via USB serial and write code to it via web IDE. Only bluetooth is gone.
Any ideas how to investigate this problem further?
