Getting a BLE error trying to get Puck to talk to Bangle #3743
Replies: 6 comments
Posted at 2021-05-21 by @fanoush
I guess it is bluetoooth stack on Puck that is BUSY - the |
Posted at 2021-05-21 by @gfwilliams Hi! I'm pretty sure you've his exactly this issue that was reported a few days ago: http://forum.espruino.com/conversations/363920/#comment15998892 I have no idea why this has happened yet but I will look into it very soon. For the moment you can almost certainly fix it by changing: to: |
Posted at 2021-05-21 by yngv126399 Thank you @gfwilliams!! That was it! And thanks for forwarding the other issue, I did a search on the forums for BLE Error 11 and I get no hits (not even this post). And @fanoush... thank you too! You have inspired me to order both an F07 and a DK08 to flash into Espruinos. I'm trying to work up the courage to make a build for PineTime. It's been a LONG time since i've worked at device level (hence my preference for JS on MCUs) but you've done considerable heavy lifting already. I've learned a lot from you both! |
Posted at 2021-06-16 by @gfwilliams Just to add I tried to reproduce this with recent firmware, but can't. I wonder whether there's something about the Bangle.js's configuration that's non-standard (like having bonding enabled somehow?). |
Posted at 2021-06-18 by @gfwilliams Ok, I figured it out (I think). This is due to negotiation of a higher MTU since this was added in Espruino 2v09. I think if you're connecting to a device with an older firmware you can connect just fine. It's when you connect between two devices with 2v09+ firmware that you have the issue. Follow this on the GitHub issue. |
Posted at 2021-06-18 by @fanoush
you need to turn off |
Posted at 2021-05-20 by yngv126399
Hey all, I'm a little lost here. My Bangle is running a watchface that is listening on a specific UUID for short strings to act as notifications (not BLE notifications, just messages). The Bangle code works fine, and I can access it from both a Web Bluetooth page and a DroidScript app. However, I can't get my puck to send the message properly. Here is the Bangle (peripheral) code snippet:
The showMsg() function is defined and works fine (just draws a dialog box and writes the string to screen).
Here is the Puck code (mostly thanks to Gordon's BLE example):
Which works fine in an HTML page using "let NRF = navigator.bluetooth;"
I'm writing my log to a file since console is disabled when I run this, and the file reads:
As i said, I know the Bangle code works, been using it for weeks. The Puck code runs in a browser just fine. Which device is "BUSY"?? Any help appreciated!
