Would like to secure puck.js with a pin code but it fails #3780
Posted at 2021-07-13 by user130485 just did a hard reset to get back to it. Removed the "keyboard" option |
Posted at 2021-07-26 by @gfwilliams Hi! There are some options shown here that might help you: http://www.espruino.com/BLE+Security#passkey-pin-pairing This should work fine to stop connections:
I'm not quite sure what you mean here. I believe you may be able to connect to the Puck but you won't be able to actually do anything. 'Changing the name' may just be the name that appears in nRF Connect - so nothing on the actual device.
This is probably safest. Also, if you're not advertising data all the time you can use less power and make it last longer. Again there are a few code examples on http://www.espruino.com/BLE+Security |
Posted at 2021-07-26 by user130485 nRF client shows writeable attributes and name is one of them. I do not know how nRF client connects to change the name (as pairing/bonding is asking for a pin code) without real pairing. But it does and it does it on a device- once changed I can see it changed when I connect from IDE as well as other devices |
Posted at 2021-07-27 by @gfwilliams Wow, thanks! I'll look into getting that changed - issue filed here: espruino/Espruino#2033 In Bluetooth LE each attribute has some security flags - whether it can be read/written by an insecure connection or not. The UART connection security flags are set so that you can't communicate without being in a secure connection (hence the need for a Pin) but it looks like you can change the name without that! |
Hi
Would like to secure my puck from connection/writing attempts.
Not sure what others use - would like some input.
Was thinking of either using a PIN code if I wanted to do something like connect/write new code, or making it connectable only when the button is pressed.
Tried using this in the onInit function
but get this error
Later I moved the NRF.setSecurity({display : 1, keyboard : 1, mitm : 1, passkey : '123456'});
into the main body of the code and added "56", as it requires 6 characted PIN code.
But I can still connect to it and it does not ask for the code
And worst part is that now I am not able to connect to it =( It connects and then instantly disconnects
