Question about assigning compiled inline c functions to callbacks #3791
Replies: 7 comments
Posted at 2021-04-18 by @fanoush
It is not clear what exactly you consider to be javascript interpreter vs native code as whole interpreter is native code but if you specifically mean parsing javascript source and interpreting it then there is no such thing if no source is involved. So if the callback is native method there is no javascript source to parse and interpret.
I fail to see the logic in the conclusion you made. Interpreting is slow so yes, it is slower (when compared to native code) before it gets to the point where it runs your native method and then it is slower again when it leaves it but the sum of total time is still smaller than having it all in javascript. There is no extra slowdown caused by calling native method compared to calling javascript method so you can only gain speed by using it. even smallest simplest native method gives speed boost, try e.g. uploading this and then measure the difference of using add vs jsadd method So just replacing method call of doing
Not easily. accessing any javascript variable (like |
Posted at 2021-04-19 by @gfwilliams Hi! In some cases, inline c can be called a bit more 'directly' - eg However for NFC and Bluetooth stuff it's not really possible - they are designed around a message queue, which pushes data from interrupt-land down to the message loop. By the time you're in the message loop and have seen that you're calling inline c, it's too late. Judging by your other posts about NFC/Inline C, I think you're at the point where you really want to be looking at compiling your own firmware to implement what you want - it's really not hard at all.
In theory, yes. You have access to these functions: https://github.com/gfwilliams/EspruinoCompiler/blob/master/src/utils.js#L74 So you could do something like: In a way it might be nice to have a bit of a standard library of functions (eg digitaWrite/etc) that can be called from Inline C |
Posted at 2021-07-29 by DanTheMan827
Would it be at all possible to call NRF.nfcSend or the native equivalent function from compiledC? I could be wrong, but it seems if I hope I'm not being too annoying with all these questions... just trying to figure out a way to write a fast script that doesn't require a custom firmware
Yes it would be... |
Posted at 2021-08-02 by @gfwilliams
Yes, that would work. OR if you know the firmware version you're using then you could figure out the address of However, as I'd said above, having the faster function won't help you, since the compiled function will be called like a normal JS function - from the event loop rather than as an interrupt. Are you trying to do something extremely special, or do you just want to emulate the standard NFC tag format that we currently do, but with the ability to write data? If it's the latter I think it makes sense for me to just add the functionality inside core Espruino |
Posted at 2021-08-02 by DanTheMan827 I’m trying to write an NFC emulator that conforms to the NTAG215 spec and can do read / write, a “magic ntag” if you will. Functionality similar to what the chameleon mini provides. The issue doesn't seem to be entirely so much the time it takes to get to the event loop and execute the code, but rather the time it takes the code to execute. I’ve implemented a good portion of the spec in pure JavaScript but the more checks I add the less likely it is to successfully scan, this is why I want to get as native and as fast as possible without having to keep iterating with native firmware and re-flashing the whole shebang over Bluetooth (I don't have a debugger for one...) I’ve done some testing and built a custom firmware with those hal function pointers exposed and I was then able to write some inlineC code that can be called by passing it the pointer and length of the rx buffer, then I respond directly from native code, it works but it weirdly is less compatible than the same logic in pure JavaScript... is there more overhead to get the pointer and jump to the compiled inlineC function than there is to just keep it all in javascript? |
That's odd. Not at all - inline C should be fast to execute.
They don't exist in Espruino :) It allocates everything in the JsVars area - if needed you could do the same using the functions that are exposed though. |
Posted at 2021-08-02 by DanTheMan827 Well, to get around malloc I just allocate a buffer from javascript and use a native setter function to set the pointer, so that's not a huge issue, memcpy I just re-implement, but that could probably be passed like the other functions that are in the firmware. Maybe it would be possible to set up the NFC interrupt so that it can execute native functions by their pointer that are assigned by That could also be applied to any event handler really, but I haven't run into any timing-critical ones other than NFC. It's not so much that implementation of NFC protocols can't be done with inlineC, but more so that going through the event loop just adds a delay that causes issues, especially if you just end up calling a native method anyways. I know that the hardware is capable of it, there are different projects doing this with native firmware. It could certainly be a module implemented in the firmware, but for my specific purpose I want to add support for non-standard NFC commands for my own use... things like being able to rewrite the entire tag payload, change to different payloads entirely and such over NFC using a custom app... I use bluetooth right now to take care of that, but nfc rx/tx is so much faster. I'll try exposing all of the hal nfc method pointers so I can use them with inlineC and just make use of those directly... yes, I know at that point I should just make a native firmware or bake it into the espruino firmware, but even if debugging is limited it's still easier to iterate using the web ide for me at least anyways. |
Posted at 2021-04-16 by DanTheMan827
If I use inline c to compile a function, and then I attach it to to say, the NFCon, NFCoff, and NFCrx callbacks, what would happen?
Would the callback see that it's a native function and execute it directly, or would it jump into the javascript interpreter just to jump back into the native code?
In my experience with inlineC, the time required to call it from javascript is more than the time to execute it, so it's faster to just keep everything in javascript, but if inlineC attached to a native callback stays native, well...
If this isn't an allowed behavior, maybe it wouldn't be a terrible idea to have a way to attach native c functions to callbacks directly that don't jump out to the javascript interpreter for at least some of the more time sensitive ones (like NFC)
also, is it possible to output to the console from inline c at all?
