Espruino and Adafruit Fingerprint sensor #396
Posted at 2014-03-03 by @gfwilliams Hi Chris, Yes, it sounds like it can be used just fine and will wire straight on. You don't need a USB-TTL converter - that's if you want to connect Espruino to a PC, but don't want to use the on-board USB socket. Adafruit also made an Arduino Library for it - while you can't use the library in Espruino, it shows how simple the reader is to use (just a few bytes of data to send). You should be able to get it running pretty quickly. |
Posted at 2014-03-03 by ChrisB Thanks Gordon :) |
Hi Gordon,
I'm a software developer but I'm kinda novice in term of electronic.
Do you think that this fingerprint sensor could be used on the Espruino board ?
https://www.adafruit.com/products/751#Technical_Details
(some examples at http://learn.adafruit.com/category/biometric)
It is using TTL Serial and I think I've read that Serial can be used on Espruino board (via usb converter) ?
Could you please tell me if this is feasible ?
Thanks,
Chris
