FIFO Full Puck 2 #4300
espruino-discuss
Posted at 2024-03-20 by @gfwilliams If you're seeing Is the issue that you are trying to record IR data at the same time as sending it, so you're basically recording what you're sending? I wouldn't worry too much about On new firmwares you could also try JIT which should improve capture speed: |
Posted at 2024-03-20 by user157578
I just record and playback some IR signals which I recorded and converted into a string following the YT Tutorial: https://youtu.be/et58ozE-Cu8?si=3XNmz9N5ImBbbeYS
var one does work fine in replaying the function Radio on my August MB300 remote the problem is that when I record mode i get FIFO_Full or >Puck.IR(mode)
Uncaught InternalError: Timeout on Utility Timer
Execution Interrupted
