Puck.js v2.22 update #4315
Posted at 2024-05-22 by @gfwilliams Hi! Yes, I think that's fine. Most likely your battery is a bit on the flat side? Firmwares from the past year or so run a self-test the first time they're flashed to the device. If you take the battery out and re-add it the Puck will start as normal with the correct name on Bluetooth. The Posted at 2024-05-22 by user158205 Thanks Gordon, surprising though as I only got the puck yesterday with a brand new battery. Posted at 2024-05-22 by user158205 Just put a meter on the battery and it's at 2.99V. Posted at 2024-05-22 by @gfwilliams That's odd - definitely should be fine then! I guess it's possible that when it tested it your finger was over it and added extra resistance or something like that. We do test them here so it must have passed the test at that point. As long as the green LED can light up you're fine though. Posted at 2024-05-22 by user158205 Hi, I've rewound to v2.21 and it's behaving as expected on power on, one single red flash. With v2.22 it gave me 6 red flashes and an extremely brief flash of the blue and green before that. When I look for it in the Web IDE, in the pairing window it shows up as Puck.js 73f5 but once paired it's calling it Fail LD2 again. So I think there's an issue with the v2.22 firmware and also the advertised name now. Posted at 2024-05-22 by user158205 Here's the screen shot.... Attachments: Posted at 2024-05-22 by @fanoush
once connected not paired? This can be IDE issue, It caches the name from previous connections (with 2.22) so may show this even if it is fine now with 2.21. Posted at 2024-05-22 by user158205 In the device selector window it says it's already paired. Is there a way to make web bluetooth forget a device? Does this extract from the logs help?
[notify_info] Found PUCKJS, 2v21
Posted at 2024-05-22 by user158205 Just answered my own question by closing the Web IDE and opening a new one! Should have thought of that first.... Posted at 2024-05-22 by @gfwilliams Sorry, I just looked into this and you're correct - it's a firmware issue. Just the self-test code (that's repeatedly checking LED1 against what it expects for LED2). I'll get a fix in now. Posted at 2024-05-22 by @gfwilliams Ok, please can you re-update your firmware to 2v22? That should fix it. Since it's been such a short time since I did the 2v22 release I've just changed the release itself rather than doing a new one. Posted at 2024-05-22 by user158205 Yep, that seems much better. Thanks. |
Hi, I've just flashed the firmware on my new puck.js to the latest 2.22 and it's come back with the name "Fail LD2", even though the flash appeared to work and it seems to be working fine. The issue I had with the ble connection dropping when the accelerometer went past 90 degrees seems to have been fixed. Did note that when I reset after the flash, the red led blinked a number of times on power up.
Any ideas? Tried it via the mobile app and the Web IDE.
