Pucks v2 IR range #4344
Posted at 2024-10-02 by @gfwilliams Hi - that's odd - and you're definitely using 'Puck.IR(data)' to send, without specifying any pins as 2nd/3rd arguments? Maybe you can check But otherwise, have you tried on other devices? It might be that what you're using the Puck with isn't as sensitive as the devices we tried with? It could also be thrown off if you're in a room with lots of other IR light (eg from the sun) Posted at 2024-10-03 by ErrorV01d Hi Gordon, thanks for getting back to me so quickly. Yes, I used Puck.IR(data) without extra arguments. The battery I did test beforehand because the puck sat in a drawer, still in its packaging, for years and thus despite being brand new I did wonder if it was operational. |
Posted at 2024-10-01 by ErrorV01d
Hi, it seems that my Puckjs (V2.24) can't send an IR signal to more than ~50cm (case on) or ~80cm (case off), with "optimal" conditions (direct line of sight from IR emitter to IR receiver of led bulb).
This doesn't seem to match the info in the docs (1.5m) or other sites (4.5m) so I wonder if there is something I'm not aware off.
Thanks!
