New compiler error started this morning, Monday /bin/sh: 1: arm-none-eabi-gcc: not found #4735
Posted at 2019-01-29 by Robin ---cont Sidebar: handle a related comment without a new post Just read your response #5 use of "compiled"
Was avoiding "compiled" a general comment or specifically related to device APA102 for that thread? Posted at 2019-01-29 by @gfwilliams Thanks for letting me know - it should be fixed now. I'd done an update/restart on the server and there was a path issue.
Yes, it's a general comment. For instance in the modules you sent me for inclusion in EspruinoDocs the Basically in all the cases I have seen so far it's just being used as a 'magic fix' - adding Using |
Posted at 2019-01-28 by Robin
Mon 2019.01.28
Using native WebIDE was able to upload "send" to Pico all weekend without error. This morning, Monday 9:00amCST noticed I am now getting the following error:
The WARNING is understood and has always been present.
Web IDE version 0.70.4
Not doing anything fancy as in these:
Just uploading a source that uses require to load modules that contain both
E.compiledC(and the keyword"compiled"all of which functioned fine previously.Beta Was this translation helpful? Give feedback.
