Endless Bootloop #4736
Replies: 1 comment 13 replies
Posted at 2022-05-23 by @gfwilliams
I'm pretty sure this is the problem. Can you still feel a physical 'click' when pressing the button? Maybe try 'massaging' the button - pressing it in and round and round a bit, and see if that loosens it? Posted at 2022-05-23 by user144377 Thanks a lot for your help. Physical click is as if everything was ok and Posted at 2022-05-23 by @gfwilliams Ok, thanks. You can get into them, but it's very much like opening an iPhone. You need to heat up the display (but not too much or it breaks the LCD!) then pull it off with a suction cup. I'm afraid it's not a desperately easy DIY job. I'll ask Christine to sort out a replacement for you. Posted at 2022-05-24 by user144377 You're right. That doesn't sound as I could open it myself without damage. Christine already contacted me. Thank you for that. Your support is awesome. Nothing to be given today! |
Posted at 2022-05-22 by user144377
My. Bangle.js 2 is booting all the time changing between Bootscreen with 'Watchdog' written at the top left saying 'Booting...' after a while, then showing startscreen with MAC adress und starting with bootscreen again.
Pressing the Button long,short, in pulses has absolutely no effect.
When catching the right time window I can shortly connect to the watch but the time till getting disconnected is to short to do anything helpfull.
It feels like the button sticks on pressed contact.
After watch battery is empty the bootloop stopps,only to start again when getting charged a little bit.
Any idea what could help?
