Problem trying to update Espruino Wifi to firmware v106 #4926
Posted at 2020-06-23 by @gfwilliams Sorry for the delay, I was away last week. Which IDE are you using? The Chrome App, or espruino.com/ide ? Had you connected a different device to the IDE between times? If you don't connect outside of bootloader mode first then the IDE doesn't know what type of device it should be using. It might be worth restarting your PC and trying again, just in case windows has got confused and thinks some other application is using the COM port. Posted at 2020-09-23 by Coder2012 Even more sorry for a longer delay :) So I'm using the Chrome App. I'm happy to report that I have updated to v1.07. I honestly have no idea what finally fixed it, i've reinstalled the Chrome IDE many times, I've switched COM ports because sometimes it sees a port then when in bootloader mode that port now disappears. Then all of a sudden COM port 5 appears in bootloader mode and boom I get to update the firmware. So relieved it's finally worked but sorry can't explain what the cause was. |
Posted at 2020-06-15 by Coder2012
I am trying to update my Espruino Wifi to v106. It was recently updated to v105 without any issues.
Here's what i've tried:
Error popup in the web ide says -
(I used the above steps to update to v105 last week and it was successful)
This time I see:
