[nodemcu v1.0] Getting onInit() to run on power-up #5249
espruino-discuss
ESP8266
Posted at 2016-01-03 by jhfoo The warning on the last line is the red herring. My nodemcu uses the ESP-12 model and I should be loading the firmware with this string: Thanks SpenceKonde for your confirmation on IRC Posted at 2016-01-04 by @gfwilliams Thanks! Glad you got it sorted :) Posted at 2016-01-08 by Arman I still get the warning :( |
Hi all, I'm running a v1.0 of Nodemcu loaded with espruino_1v84.tve_master_d8dec28_esp8266 of the firmware.
First off: I must say that JS on the ESP8266 is SO much more stable than the stock LUA! The library support in comparison is amazing too.
Now to the problem: I've got my codes working. save() wrote my code and soft-booted. Everything is perfect. But when I do a hard reset (via esp8266.restart()) nothing starts up. I suspect this has something to do with it (screen upon startup):
Can someone advise how I should correct my firmware install?
