Serial3 on C10 doesn't seem to work. #577
Posted at 2014-09-14 by DrAzzy aaaand I had everything working (with serial4, of course). And then I send another command to nixie tubes... POP uh, yeah. Burned trace right next to the MCU. No idea what happened or why. Wasn't touched or anything, and was 100% working just minutes earlier. |
Posted at 2014-09-14 by @gfwilliams Burned trace? :s Since the MCU can't provide that kind if power, it seems like something came off the nixie tubes. There's a bug open about the C10 issue already: espruino/Espruino#409 Thanks for checking about Serial on B10 - that helps. I think on this chip it's not enough to 'move' Serial3 to the right place. .. You need to move Serial4 out of the way too! |
Posted at 2014-09-14 by @gfwilliams Got a picture? I could probably tell you what the wire is... It might help? And does the board still work? |
Posted at 2014-09-14 by DrAzzy Oh shit, just realized it sounded like I burned out the espruino. No, that was a smart nixie board that burned out, next the mcu on that board (an atmega). Though, if I have to buy a new one, that's more expensive than a new Espruino ($50 for a top + bottom board - plus over an hour of assembly). Only espruino issue is the thing about the serial |
With the SmartNixie tubes, I do the following:
Not sure what's going on here.
Serial 4 on C10 works, as does Serial1 on B6 or A9, Serial3 on B10, and Serial5 on C12.
But serial 3 on C10 doesn't seem to work...
