How to best handle http request errors #598
Replies: 13 comments
Posted at 2016-05-25 by @gfwilliams Thanks - That looks like an issue with the SIM900 code then. The idea is that the You've made your own tweaked module haven't you? I think in the CIPSTART case, literally just removing the line You could also look at where the handler for
Posted at 2016-05-25 by jonreid Yes I have already removed the exception throws but I thought that was not enough to get the error to come back through the network library - but maybe I should recheck that. I currently have my own callback in both the CIPSTART fail and CONNECT FAIL case - but then I dont know when the socket etc is freed. |
Posted at 2016-05-25 by jonreid Just looking at it now I see that the 'send' function is waiting for the socks entry to be set from 'Wait' to either 'true' or 'undefined', the latter will then trigger the -1 return in the case of the error. So in theory without the throw this should be working - I will check that again |
Posted at 2016-07-06 by sp33c I think it is not a problem with the SIM900 code. It is regarded, how AT commands get executed at the modem. I can reproduce this, when I run shortly after another two command, awaiting replies from the modem. e.g.: isOnline(); networkTasks() (my own code)
Posted at 2016-07-06 by @gfwilliams Ahh - yes, maybe the driver should be more aware. If you do one command while waiting for the result of another it should throw an error, but you can definitely get into a position where you asked it to do something (like connect) and it's said |
Posted at 2016-07-06 by sp33c I really think each programmer should know this. We're dealing on a very low level on that hardware. Everyone has to be careful how he deals with it.... So I would say, not for sure the module needs to handle it. I have to think about it. In my case I was just receiving the IP-Adress from the SIM900 on timeinterval with a special AT-command (not with the SIM900 code). At the time this command did not resond properly, and I started the request, it got mixed up and the request failed with above error. Now as solution I do one operation at a time. I prevent status requests on that hw, when I am aware I need to make a request. I personally gave the last one the higher priority. |
Posted at 2016-07-07 by @allObjects Introducing a queue can help with that... but the queue entry has also to include what has to happen when the result becomes available. I have built a sequencer / gl0bal controller that supports such needs including inserting entries that 'cut into the line': sometimes the response of a currently going on request cycle needs to trigger something else than what's next in queue. (see this post and posts referenced in there. |
Posted at 2016-07-07 by Wilberforce Perhaps the new |
Posted at 2016-07-07 by sp33c I will try. I didn't know I could use promises on the espruino. great. |
Posted at 2016-07-07 by sp33c Another thing (maybe offtopic) After a certain time the requests also do not get through I get the error: Uncaught Error: No free sockets. when is the netcallback.create to be called in SIM900? |
Posted at 2016-07-07 by @gfwilliams Generally it's called when you make a client or server socket. If you're getting no free sockets it's either because connections aren't closing for some reason, or maybe the SIM900 module isn't catching the socket closed message for some reason and updating its internal list of used sockets. |
Posted at 2016-07-07 by sp33c I think, the AT-Module must lock AT commands until they responded properly. I overthought it at this level. |
Posted at 2016-07-07 by sp33c -deleted- |
I am making POST requests to a web server via SIM800. I have a req.on('error', function(e)) in place but I find that only catches one particular error (I cant remember the code right now)
However in the SIM900 code if either the CIPSTART command fails or there is a CONNECT FAIL, even though the SIM900 code was throwing an exception and setting the socket to undefined - the http request function does not generate an error. I assume there is no mechanism to ripple those errors back through.
So for now I have implemented my own callbacks from the SIM900 code to capture those errors so I can retry. But the question is, how do I ensure the existing http request is properly killed off so I dont leak memory from retries ? Or worse the request code ends up returning something (error or not) after I have already captured an error and begun a retry.
