Problem With MQTT module #6469
espruino-discuss
ESP8266
Posted at 2024-03-13 by @MaBecker look for module https://www.espruino.com/tinyMQTT Posted at 2024-03-13 by @gfwilliams As @MaBecker says - this is probably as it says - the ESP8266 is quite restricted with RAM so it's running out of memory. Likely you are uploading to RAM and if you upload to Flash that will help, but using tinyMQTT will help too |
Posted at 2024-03-13 by user157729
Hello, I'm encountering an issue with the MQTT module.
I have a board WeMos D1 R2 with a ESP8266 and when I attempt to use the MQTT module, I encounter this problem:
New interpreter error: LOW_MEMORY,MEMORY
The return of mqtt.create is empty. So, I would like to know how I can bypass this problem because I would like to use the MQTT module.
I'm using the espruino_2v21_esp8266_4mb_combined_4096.bin and i would like to know if this is the most recomended firmware to my esp8266 board
