setWatch and neopixel error #6530
Posted at 2021-05-04 by @gfwilliams Hi! Thanks for this - I can confirm it's the same for me too. HOWEVER if you're using the latest 2v09 firmware, it doesn't crash unless you short D31 to something (but you do get pin state change events).
You can't use pin D22 since that has to be used as a clock output (it can't be disabled). However, it seems that the hardware issue of not being able to disable pins is much wider spread than I thought: https://infocenter.nordicsemi.com/index.jsp?topic=%2Ferrata_nRF52832_Rev2%2FERR%2FnRF52832%2FRev2%2Flatest%2Ferr_832.html The implication here is that it's not just the clock output pin, but all of them. Generally to set a pin to unused, you set all the bits in the register to 1, so it's probably no coincidence that the 31 from D31 is binary 11111. I've just had a go at setting the outputs to other things, but with no success so far. So I'm afraid, at the moment, you'll just have to assume that pin D31 can't be used when you're using Neopixels. I'll file an issue for this though and will see if anything can be done about it.
Yes, that's right - you can probably change it by manually calling Posted at 2021-05-05 by AndreyVS Gordon, many thanks for the feedback and a useful link to NRF errata!
On v2.08 pinMode change did not work. But on v2.09 LED lits normally after setWatch :) Watch is not raised. |
Posted at 2021-05-03 by AndreyVS
Hi! I've got a problem & solution (took me several days to find it.. phew!..).
I set watch to rising (or falling) D31 and try to lit a neopixel on D2. And Puck (v2.08) hangs..
If I set e.g. D30 instead of D31, all's ok. The issue is same on a new Puck without any connection to neopixel, one can try the code out of the box. Would be grateful for a comment:
