How To Debug js code in the board? #6611
Posted at 2015-09-15 by @allObjects ...you are asking a lot... That's why I often develop on the PC with a clear separation of concerns and emulating the hardware elements... for applications with UI or MI - user and machine interface - I encapsulate the UI and MI and apply the MVP - Model View Presenter - pattern. I was working on some monitor / testing approach using the aspect oriented programming, but the resources are just a bit tight. For lower level, Espruino has a trace that allows capturing of what's going on in the interpreter. But I'm not aware of an interactive debugger... (the ugly, dedicated 'console.log' is the candidate... and if the communication is to slow, some stuff has to go pushed into an array which later on dumped... Since the console accessible while running connected to the IDE, you can setup some interrupt/interval driven loggings to the console - either included in the code or entered in the console. The above option is used in the IDE testing - more a monitorig - function as available (in BETA) in the IDE. See settings - TESTING. It has really nice functions to get started with monitoring what's going on in the code. Posted at 2015-09-15 by @gfwilliams I'm afraid there's no interactive debugger. You have to debug with print statements, by executing functions one by one, and by looking at the values of variables. It's something that I'd like to add at some point in the future - I have an idea of how it can be done without too much trouble - but it's not there now. Posted at 2015-09-15 by LifangXia OK, I understand. Posted at 2015-09-16 by jojo @gfwilliams Posted at 2015-09-16 by @gfwilliams Thanks - yes, it's just a matter of finding time for it :) Posted at 2015-09-16 by alexanderbrevig It got me thinking. Maybe a way to do this is to have a 'bullet point' in the IDE inject something at the end of that line. When the parser reaches that thing f.ex Just had to get it out of my head, probably entirely wrong way to go about this. Posted at 2015-09-16 by @gfwilliams Actually I hadn't considered that, but it's a really interesting idea. I was planning on adding checks at various points in the parser, but if I were to put something in the lexer I'd only have to put it once. In fact if it were to trap with a character that wasn't allowed in the input (like I'm thinking something like node's implementation where Espruino entered a ... problem is, if I do add debugging then the next step to have a nice graphical debugger in the Web IDE (eg, the ability to hover over variables as @AlexanderBrevig suggested), and that's something I don't see myself having time for. Posted at 2015-09-16 by @allObjects As soon as you have to touch the code (manually), it's getting messy. I understand that it is a challenge, because between source code and uploaded code there is no simple mapping - for various reasons. One major uniqueness of Espruino's is the fact that it runs on the source code. Taking advantage of that should make it possible to have some kind of a source map. Since this is major work, a slightly different approach could be taken: holding on in the IDE of the uploaded / runtime code. It would at least cover the non-dynamic stuff. It means, it does not cover the dynamically loaded modules loaded from board/runtime accessible SD cards at run time. IDE and interpreter can then exchange information / markers... yes it slows down the interpreter, but it could be built to the point that it is to the order of established break points. Since there is something like a PC - program counter - that 'runs' over the code, it shoud be possible that at statement begin the interpreter could check against a list of break points and stop there. If the uploaded code('s reperesentation) is still 'too far away' from the code as it is stored by Espruino on uploade, not the uploaded code is held on, but the code as it is on Espruino is down loaded into kind of a debugger and used for debugging. This are just all ideas. Since we are in an object-oriented AND very dynanic world, I'm thinking about aspect oriented programming using (debug) annotations. The (debug) annotations are considered on code upload when upload for debug is enabled. Same thing - option - for module building (and may holding on to 'for debug built/minified' modules. May be this looks like node's approach. For now I'm thinking more of having some simplifying support for unit and regression testing of modules on Espruino and building my application as composition of modules - of the rack modules and custom modules. It's not perfect and looks like 'heavy' in process, and it also does not help to figure out some very strange, unexpected, temporary behavior. Having a solid unit/regression testing though in place reduces the potential of such behaviors immensly. Doing TD / XP development is for me the approach. Any other approach interferes with the code at runtime. Posted at 2015-09-16 by @gfwilliams Yes, I'm hoping that you won't really have to change code manually at all. But for now the idea is:
If you wanted to add a breakpoint, you'd add a Posted at 2015-09-16 by @allObjects Sounds like - actually IS - a very good plan. The way I understand is that the IDE transmitts something on that For now, I would not even have a separate prompt: just the console, because from there a lot is already accessible:
Btw, I was thinking that this entering into debug mode should also be something based on a pin changing state (triggered by a pressing a connected button). Actually very simple: it is already there: a Regarding the keyword statment Posted at 2015-09-16 by @gfwilliams Well, Ctrl-C already breaks out of execution so seems like a good starting point. At the moment ctrl-c will only break out of something if it's busy for 1/4 sec after you press ctrl-c, so you'll only get into it if the code has basically hung. To be honest, if you want to talk to Espruino via the Web IDE it's got to send a control character via the terminal anyway - for the moment it might as well be ctrl-c :) Posted at 2015-09-16 by @allObjects I see, you mean sending a Posted at 2015-09-17 by @gfwilliams Ok, I've just come up with a branch for the debugger. There should be builds with it in here To use it, try uploading:
So overall, I think it's actually pretty useful as-is? Posted at 2015-09-17 by @allObjects That helps already a lot...
Posted at 2015-09-17 by @allObjects Other options:
Posted at 2015-09-17 by @gfwilliams Just updated with this build.
Yes. The idea is that the Web IDE will be able to get out of debug mode automatically with repeated Ctrl-C. You don't want to get into trouble if you click 'upload' while debugging.
This is just what node.js did. It's probably not too painful to change it.
Basically - you just have to prefix it with p. It's like GDB (ish).
Not possible right now :(
In GDB that's called
You can do Posted at 2015-09-17 by @gfwilliams It's got You'll also find some documentation here. Feel free to issue some a pull request if you think it could be updated somehow. Posted at 2015-09-17 by fdufnews Thanks it will help Posted at 2015-09-17 by @gfwilliams Just merged this into master. Latest build here - it's looking really good now. Posted at 2015-09-17 by JumJum Just tried "Latest build here",
Checked flashing with a V1.80 and that runs fine. Posted at 2015-09-17 by @gfwilliams The selectbox was because you hadn't connected to the board first, so it couldn't check. Did you actually go to the link above and select the right binary? The fact it can't find the bootloader sounds like you didn't reset it into bootloader mode? (with the blue LED) I just tried here with an old board and it works fine for me. Posted at 2015-09-17 by JumJum Connected to the board first. After restart of computer, now it works. Looks like a windows/chrome problem. Posted at 2015-09-17 by JumJum First test, based on above example works fine. It's a big step forward, I love it and will do some more testing tomorrow. Posted at 2015-09-17 by alexanderbrevig I'm blown away @gfwilliams. Really good job! Posted at 2015-09-17 by @gfwilliams Thanks! I actually had call to use it in something this afternoon (debugging a temperature calculation) and it's already saved me a few minutes. Should have done it ages ago!
Use
Posted at 2015-09-17 by DrAzzy That's amazing! Can't wait to give it a try. Just gotta write some bugs, but as everyone here knows, I'm real good at that ;-) Actually, what's most amazing is that this was requested just two days ago! Posted at 2015-09-17 by asez73 Hi, I faced some "random" out of memory errors after hours of no memory leakage running program. So if would suggest, humbly, some watch point based on free memory. This could allow for tricky unfreed memory after garbage collection. I mean local objects not really freed as beeing still referenced either recursively / undirectlyor through anonymous functions still accessible in some cases... And yes, @gfwilliams is doing a tremendous demonstration of his capabilities to answer to his customers's problems.... I am really impressed by your reactivity! Posted at 2015-09-17 by fdufnews I just gave a try and found it simple and efficient. Thank you @gfwilliams Posted at 2015-09-17 by @gfwilliams Great! To be fair there was a bug filed for it 2 years ago, so it has taken a while. I just found a reasonable way to do it. Memory debugging is difficult though. I can't think of a nice way of doing that at the moment, but will think on it. Posted at 2015-09-17 by cwilt Nice addition. Posted at 2015-09-18 by asez73 I was just dreaming it could be linked to the garbage collector, like a kind of post-mortem debugging with the help of the ide.... Posted at 2015-09-18 by @gfwilliams Well, the garbage collector doesn't really know very much about what's going on. I'm not quite sure I understand your problem - you actually have a leak in your code (rather than Espruino itself?). You can run the debugger when memory usage gets too high: And you can also see how many variables each object is using with: For instance you could dump all your global variables and their sizes with: Then you could keep track of those and see if any of them rise up (of course it could be a variable in a closure that's causing you problems). If you've got specific problems debugging it I'd post up in another thread though - I think the answers would be helpful to a lot of people. Posted at 2015-09-18 by asez73 Ok, I'll open a specific thread for my problem: it could be either a variable in closure although I don't see how and also a serial buffer overflow. Posted at 2022-01-29 by Mark_M old topic... Posted at 2022-01-31 by @gfwilliams No - debugging doesn't work in the emulator I'm afraid. |
My question is:
may I debug js code in the board? such as C language, step/step into/...
