weird error: You have more open brackets than close brackets. Please see the hints in the Editor window. #6711
Posted at 2023-05-24 by user155553 Same problem here, trying to upload a code that used to work but no longer works and getting the same error. Posted at 2023-05-25 by @gfwilliams Argh, ok, thanks - sorry about this. I'll take a look and get a fix in in an hour or so - we've had some changes in the 'development' web IDE for a few weeks that fixed an issue with regular expressions and I hadn't had complaints, but I pushed them live yesterday - so maybe this is related. Posted at 2023-05-25 by @gfwilliams Ok, it should be fixed now - just make sure you his refresh on |
Posted at 2023-05-24 by user155285
I started to have the open brackets / close brackets error on a script I have been using for a while and was compiling fine till today. No changes have been made to it . There is no error visible in the IDE
I found out this function is where is the problem but I really don't see any brackets error on it ??? :
function rescaleToMidiCC (value, oldMin, oldMax){
newMin = 0;
newMax = 127;
rescaled = Math.round((value - oldMin) * (newMax - newMin) / (oldMax - oldMin) + newMin);
rescaled = Math.min(127, Math.max(0, rescaled));
return rescaled;
deleting this part of the code and the script compiles
